I know....we can design a spray plate that bolts under the stock manifold with an injection nozzle at each intake port....this would help with even cylinder injection...about as close to the cylinder as you're gonna get without tapping the head...
Hey Doug, I make moonshine in the summer...maybe i can try that instead of windshield washer fluid...whatcha think haha? Think that'll have enough alcohol content?
im·ma·ture/ˌiməˈCHo͝or/Adjective
1. Not fully developed: "immature fruit".
2. (of a person or their behavior) Having emotional or intellectual development appropriate to someone younger.
If you can't find it at your local hardware store, I have a way I've been using for years to create my own.
If you break down the word methanol, basically it means liquid methane. Methane is simply natural gas. Natural gas is the same stuff you use to cook with at your house, unless your a DA with an all electric house.
What you want to do is pull out your oven and disconnect the gas line from the back of the oven. Take a five gallon bucket and fill it up half way full of tap water. Take the gas line and stick all the way to the bottom of your bucket full of water so your sure to make contact with all of the water molecules. Perculate for 15 minutes and remove hose. This will give you 20%methanol + or - 20%.
my egts are too hot so i hooked up a -10 line to a 300 gallon tank in the bed of the truck with a 300gph pumping it along. works great egts dont get over 60*F
make sure you inject it pre turbo...i just use a garden hose and a switch in my cab to turn it on and off
