Hey guys I'm wanting to make a list of all the mods that a guy with access to sme basic tools can do at home. Only the low budget mods if possible. I'm not sure if there already is a thread with them or not but I couldn't find one. I would apretiate all the help. So far I only have a few that I know of:
The Zoodad intake mod
The Banjo bolt mod
Please help me make this list grow thatnks everybody!
I apretiate the help but I'm trying to compose a list of things on a lower budget scale. And I hear ya about taking the engine apart, I've had my engine down to the egr cooler with what my buddy had in an old toolbox lol.
Change out your FPR to the upgraded one.
Add some gauges. Relatively cheap.
Punch out your cat. ( not your wifes pet)
Add a coolant bypass filter.
Unplug your EGR valve.
Load up your custom tunes off your SCT. (What?? Don't have one? Check with some of the vendors, they will hook you up. )
CCV mod.
That's about all I can think of off hand. Good luck with it.
Add some gauges. Relatively cheap. Punch out your cat. ( not your wifes pet)
CCV mod.
For the CCV Mod, use the search feature, i know there is a thread on this since ive made two of them. snb:
The Coolant filter kit is a must! Cheap preventative maintenance!
Harpoon mod is great. It gets you to 29-31 gallons in your fuel tank without having to make any real stops for foaming diesel fuel. Do a search. One of the first and best mods I ever did. :ford:
Yup looks like a good mod. If I ever have a reason to drop the tank or pull the bed I will be doing that mod. Till then ill master filling my truck with no foam to bad I can't just tip it like a beer glass
The Banjo bolt mod
The Harpoon mod
The High idle mod
The ccv mod
Punch out/delete the cat
Unplug your egr valve
Please help me make this list grow. I apretiate the help everybody!
My favorite Mod is universal for almost all makes and Models. It is the Beverage Despensor Mod. All you need is a working windshield washer tank and pump and some extra hose and your golden.
* Flush the wind sheild washer fluid tank and factory lines to remove all contaminants from the privious fluid.
* Connect the extra lenth of hose and run into the cab. The only one I have seen was run through the vent in the middle of the dash. It ran through the vent and stuck out about 1.5-2".
* Fill Freshly flushed Beverage Despensor tank with favorite beverage. Legally this should be NON ALCOHOLIC.:doh: I Do not recomend Drinking and Driving.ullover:
* To test, ingage Beverage Despensor switch (Former windshield washer fluid switch) and watch as the cup fills up and the the windshield wipers move for your enjoyment.
This works better if you have an Ice cooler in the cab or during the Colder Months of the year. Things tend to heat-up during normal driving.
Note: The line running to the washer fluid ports should be disconnected during Beverage Despensor Mode. It doesn't really help to have Mt. Dew or Coke dispensed accross the windshield.
Look for the escape/ mariner 6 disc mp3 player. They are a little bit harder to find than for the 99-04 trucks. I have the shaker 500 out of a mustang in my truck, I had to adjust the mounting but it was very easy and it works like stock with my steering wheel controls
hey bro... best bang for the buck by far go to puredieselpower.com get the stage 1 upgrade comes with a 4 inch turbo back exhaust kit.. an s and b filter kit works well with the zoodad mod and a sct tuner all can be installed def in a few hours and makes a huge difference on performance and fuel mileage .. try that on ur rig wont be dissapointed for sure .. later
I apretiate the advice. I have a 4 inch back to dual 5" stacks and a ppe xcelerator. Everyone says to try an sct with custom tunes so I might give it a shot. The ppe makes an incredible difference so I will be surprised if the sct can crank out anything more.
No reason to change the stock filter. The aftermarket is not going to out flow the donaldson unit where the stock engine makes it power at least on stock sticks and a turbo. Might want to go aftermarket if you want less filtration though... That is a great benifit of those systems
How about an engine oil bypass or egr cooler with plugs welded in for us that are lucky enough to have smog testing. Has the high idle mod been suggested?
on mine.... i just unplugged the wire under the drivers seat. took like 3 seconds and no more dinging. no key on key off bs
