No they are not all the same but not so much quailty to worry about as different spec. You need to get one matches the spline count of your gearbox. There are two different number. Only way to be sure is get under there and count teeth. I was not thinking and had mine sent without counting to confirm so we will see. I have a 50/50 shot.
If its made for your year and your exact lift then it will work fine..in conjuction with a correctly made drop track bar bracket thats made for the same lift..
Something I learned the hard way... The 9 spline between the flats has the flats at 90* to center... The 8 spline has them at 45*...
4 Steering boxes later, this is forever engraved in my head...
