Double din in a 04 f250 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Car & Truck Audio
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 12-23-2010, 05:26 PM
2004Stroker6.0's Avatar
2004Stroker6.0
Offline
Decorated Deer Killer
Member's Gallery
First off yes im new here, but i wanted to put up a thread with your guys help about actually in detail completing the install of a double din in a 2004ish f250/f350. When i bought my truck i wanted to put one of these good lookin beasts in my truck. After searching the web i found alot of posts about it but not too many with any details other than " yea guy trim dash and get a kit". I also want to say this was my first stereo install so i had no idea what i was doin.
I went online and purchased a pioneer touchscreen, went to the local audio store bought wiring harness and a double din trim kit. This is where it got difficult for me. I had to find a kit that has the clearance for my radio and mounts my radio and locks it in the dash. Well after three stores bam an indash mounting kit and trim ring approx $21. The bag said the trim mount and ring was for Ford Explorer.
Again this is my first install, so take your harness you bought and the one from the stereo this was the simplest part. Buttsplice all wires together jus color match them.
Next was the dreaded DASH TRIMMING AHH. I dont know about many people here but any sort of cutting in my baby is just heart wrenching. So what i did was one of the measure 15 times cut as needed. first i held the trim ring up and "sharpied" the outline of what needed to go. Then tested cut and tested again. After about 45minutes of dreaded cuttin bam it is clearing. I also had to grind down 3 plastic tabs that protruded down, and remove the two 7mm bolts to clear. Bascially i removed most of the upper lip and entire bottom lip as for the side lips i will get to that in a minute.
Next i screwed the two plastic plates to the stereo (with what are the mouting and locking plates). They were defined by left and right simple enough.
Ok next i tried to install the stereo, nope it wouldnt fit. Now those plastic side plates made it too wide . I couldnt cut those side tabs out because they lock the stereo in with those plastic plates (preventing it from flyin out). The next plan of attack was remove the dash "that is the radio part" (simple just clicks on/pops off). I had to install the stereo from the rear of the dash. I just slid it in the "well" and the had the enjoyment of tryin to get the plates on the stereo to lock on the front dash part which is removed. So basically i have the front of the dash in my lap with the stereo slid in main dash and tryin to "click" the stereo to the front dash with it off while in the main dash part. if any of this makes sense? . Still not fittin those side plates on stereo bow at the front to lock on the outter dash trim lips, but they were jus a lil too wide soo i gently and barely ground down the outter dash lips jus a sliver and bam stereo clicked in and locked
Next plug your wiring harness together with stereo and factory plug. Put the front dash back on with stereo. Popped dash on while aligning back dash and front with stereo.
Next click trim ring on and DONE!!!
My indash also plays DVD's so i had a long green wire which was the E-brake switch so dvd would play i ran that under the dash and you can do as you please with yours. I did mine my own way lol.
Reply With Quote Quick reply to this message Go to the top
Old 12-23-2010, 11:23 PM
2004Stroker6.0
Offline
Member's Gallery
Re: Double din in a 04 f250
any pics you guys have im sure will be a great help to other guys doin this i wish i would have had some before and after pics and the like.
  #3
Old 12-24-2010, 02:52 AM
jdc753's Avatar
jdc753
Offline
6Leaker
Member's Gallery
Send a message via AIM to jdc753
nice write up. Pics I'm sure would help out specially for the others to have a better understanding of it, but overall great description.
__________________
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
  #4
Old 12-24-2010, 12:46 PM
2004Stroker6.0
Offline
Member's Gallery
thanks
  #5
Old 12-24-2010, 04:34 PM
rum4's Avatar
rum4
Offline
Retired Army
Member's Gallery
Ok so now I need ot save money and use this to install a new stereo in my truck. Might need to drive to Virginia to get some help from 2004Stroker6.0. Thanks for the write up.
  #6
Old 12-24-2010, 04:39 PM
2004Stroker6.0
Offline
Member's Gallery
Any time but as for you Rum4 if im not mistakin all the newer models a double din install is twice as easy it doesnt take as much modification.
  #7
Old 12-24-2010, 06:07 PM
jdc753's Avatar
jdc753
Offline
6Leaker
Member's Gallery
yup 05+ trucks are drop in deals, still some work removing the dash and reinstalling the head unit but much more straight forward than the 99-04 trucks.
Rum4 what year truck do you have? Is it the 08 in your avatar?
If so this is what you'll need
You'll also need to pick up a dash kit for the trim ring and 2 side mounting brackets, and a wiring harness adapter, but there will be no trimming or anything custom involved.
  #8
Old 12-24-2010, 11:55 PM
rum4's Avatar
rum4
Offline
Retired Army
Member's Gallery
No the one in the avatar is an 2010 but the one I am talking about is my 2004 F350 SRW Lariat 4x4. My wife used to drive it but she went and bought a Nissan Cube so now it is starting the "project" phase.....
  #9
Old 12-25-2010, 01:18 AM
2004Stroker6.0
Offline
Member's Gallery
Well I am sad to see her get a nissan but "to each there own" lol But i guess it worked out in the end you now have a nice place to start a project. I will try and get some pics of mine up sorry i am bein lazy it the holidays and all lol
  #10
Old 01-10-2011, 04:48 PM
b5dart70's Avatar
b5dart70
Offline
Member's Gallery
Two questions:
1) What pioneer touch screen did you go with? I am looking for one with the front ports instead of running cables from the back.
2) In order to watch the DVD's while on the go did you use a bypass or something else?
Thanks,
Bob
__________________
2003 F250 CC SB 4X4 6.0 Auto
Current Mods:
Updated Ford Injectors, Air Raid Intake, Evans Coolant, High idle switch (1200RPM), no muffler (straight stock pipe from turbo), Auto-Start, HPOP, ICP sensor replaced, EGR disconnected, Tekonsha Odyssey brake controller.
Future Mods:
ARP Heads Studs w/new gaskets
SCT x3 via Innovative sitting in box
  #11
Old 01-10-2011, 11:45 PM
Wojo
Offline
Member's Gallery
i got the pioneer AVH-3200BT which has built in bluetooth. sonic electronics sells it for 379 bucks. i installed mine exactly like this guy. fits great and looks great. it DOES have front inputs which i like. and it will play audio/video from an iphone or ipod touch. i have sirius hooked up directly to the back of it and it controlls it great. i bypassed mine to watch dvd's while driving by using this diagram.
http://i228.photobucket.com/albums/e...ngforRelay.jpg
  #12
Old 01-11-2011, 03:29 AM
cwh's Avatar
cwh
Offline
Member's Gallery
Thumbs up Re: Double din in a 04 f250
[QUOTE=Wojo;1310189]i got the pioneer AVH-3200BT which has built in bluetooth. sonic electronics sells it for 379 bucks. i installed mine exactly like this guy. fits great and looks great. it DOES have front inputs which i like. and it will play audio/video from an iphone or ipod touch. i have sirius hooked up directly to the back of it and it controlls it great. i bypassed mine to watch dvd's while driving by using this diagram.
You meant so the kids can watch DVD's right?
__________________
1997 F250 7.3 CC SB D60 "The mechanical bull"
  #13
Old 01-12-2011, 11:45 AM
2004Stroker6.0
Offline
Member's Gallery
I installed the Pioneer AVH-P3200DVD In-Dash Double-DIN DVD Multimedia AV Receiver. You can go one step above me and get the one with bluetooth which is the AVH-P3200BT. I liked my model because it was cheaper and i dont need bluetooth. But like you said you wanted the inputs in the front and the two models do have all features in the front which is what i wanted too(SD card, AUX cable and USB). As for the DVD bypass i MUST say becareful it is illegal in alot of states to watch and roll so to speak. I did this to mine too tho there is a little green wire which goes to your emergency brake as a ground. That ground tells the screen to work with a dvd on and the parking brake set. what i did was cut the end off put it on a switch. Because these models are too smart to just ground it out, the ground must be regrounded after truck is on resembling the parking brake being applied. I hooked the switch wire to a ground under the dash not the E-brake. Now all i do is just flip a switch under the dash (telling the radio its e-brake cable is regrounded and on) after radio is on and press ok and it plays. I didnt want an ugly switch on my dash so i mounted it under there. Dont know if there is a better way to do this but it works for me and i like it alot.
__________________
2004 F250, CCSB, 6.0L,
4" Turbo Back,
5" Y-Pipe Bed Kit,
6.25" Black Chrome Mitre Stacks,
Exhaust By Twisted Diesel,
SCT Custom Tunes by Eric@Innovative,
58V FICM by Swamps,
Airaid Intake + Zoodad Mod,
4" Lift and 2" Shackle,
Black Moto Metal 951's,
35/12.5/18 Toyo M/T's,
Pioneer Indash Touchscreen and MTX sub.
  #14
Old 02-07-2012, 02:36 PM
DoubleTake's Avatar
DoubleTake
Offline
Member's Gallery
About to get the AVH-P4300DVD. How hard is it to get the dash completely off for the install? I have a lot of accessories I want to run while the dash is off.
From what I have read, this is the right kit?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Also, guessing this is the right bypass to get, just that simple?
Thanks
__________________
2003 F-250 7.3L FX4 CC SWB
-AFE intake
-Silverline exhaust
-DI 6 position chip
-Autometer gauges
  #15
Old 02-02-2013, 11:34 PM
powermax04
Offline
Member's Gallery
Hey I gotta 2004 im putting a 05 lariat dash bezel in along with Harley gauges and was wondering what aftermarket radio would work best ? Thanks!
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 445
'99 stroker, 00powersmoke, 01_F350-SD, 02-stroker, 02EXCURSION, 03/6.0EXCURSION, 03kingranchstroke, 04pstroke, 04_Stroker, 06amarillo, 06deezel, 06PowerTokin, 06_stroker, 07hs2000, 16yrenthusiest, 2000wa250, 2004Stroker6.0, 2006.1f250, 2stangs8689, 350factor, 402notch, 5150Mikey, 6.0 six speed, 6.0&SN95tagteam, 6.0Monty, 7.3, 7.3freak, 7.3Texas-Stroker, 8607121, 8inchstroker, 907DAVE, 91turbogsx, 92f150300six, 92fordcummins, 94powerstroke, 95gasser, 98slowstang, 98stratusryder, 997.3PSD, 99F250Smitty, 99oilburner, abrown3mtg, ackdog, ad40434, ajennings, ajfetterman, AKclackclack, alk8778, amcervantes, amdriven2liv, Amstaff, AZmike, b5dart70, BackwoodsPowerstroke, Bajadave, Bamboo, Barnbuilder, basicbajax, bbmxandfmx, besthunter51, bhougham, Big Iron Customs, big smokey, bigbadford01, BigDeal21, bigern515, BigRed97, bigrngyj, BigSmoke, bigstrokin33, Bill R, billd, Bjesse, bjt, bknight187, blackbetty13, blakes, Bleedgreen, Blue6oh250, Blueknightcrew, Bmiller5, Bombsquad450r, bondsman, boobin, boostaddict, bpb424, BradE99, Brian918, brianb7.3, bryan.d, buckharding, Bumpin, BumpRacerX, bwstone92, ByrdDog, c1ark, camaroicoc, captivahach, captzach, carpenterhut93, Carson510, ccrowd, CGMKCM, chad88, cheezydad, chizetown, chopper, Choupique108, chrgd2000, chrisreedtn, clackclack, co04cobra, Codydiesel, Colt_FX4, CoreyKalman, cowboyengel, crashingone2002, crashtest22, Crawler374, Critical, csdragacer, CTFFEMT, CumminsRanger, Cuttintracks82, Cutty72, cwh, Cwillhite04, cwprosser, cyberdiamond, cygnus, CYIZEAL, Cypriss32, D2HP, dackoff, daturbosix, Dboy11, ddbck, Derek2001, Diesel Mack, diesel_84, dmeis, dmstrucks02, DNTTRY, Donnief, DoubleTake, Drew2010, drodkey, DSGDB6.0, Dudley Glass, duece, DukesPSD, Duracrap, dustinz85, Erik727, ernieb143, ewatts2003, F-250-Owner, F350F351, F350POWERSTROKE, F350R, factorydefect, Flash and Flare, flexyford, flip2spin23, florida 6.0, flyboy41, flybykota, flynlow05f250, fordfan30, Fordfreak4life, Forged01, fpOwerstRokeD, freeride808, FSJPat, galla35, golfer, gonefishin3, grantw1221, grecoface, Grey91, greybush, gt4660, gtmustang00, Gunny, hardint, HartwoodDiesel, hawaiiandiesel, hienergy557, highlandre, hilber, hill_billiez, hivoltg, honda313, Honeyshucks4, Horsepowerfarm, HVACfarmer, ibantu, Ignorant1, IHPowerstroke7.3, IL7.3 Powerstroker, internationalpsd, ironworker25, Ithumpwheniwalk, Itsfordog, Jacks_6.0, jag6510, jamcconnell2, jammin60, Jason.Horath, JB426, jdc753, jdi731, jdjd, jdubb823, JDubya88, JerDirte', Jeremy, JESTERxHEAD, JimmyO, jimwesselman, jjdup, jlwalker9, joshallen88, jp115, jqcsteve, JRamseyer, jsturki, justin202, Justin@DP-Tuner, justind, kaker123, Kbuck11, keanoknick, Kgantz, Killer48, kingrancher04, KingRanchSick.0, knightrally, kst8catfan, kyle43335, kylefaulk20, KYmxracer52, LazyLS1, Leadsled, leoneo01, LHM, loc0gring0, LOOSEWHEEL, lowbedriver, lrazer, ltljoe22, LttleGreenRam, luckyj, MacAssassin, maps, markdeespot, matts05f250sd, Matt_P, maxxisracing, Mayna, mbg75, mdfirefighter, milehighstroker, milesengineer, mirounga, mjpage69, mnwake, moabbound, Monumentally, moremph, Motomez, Motownfire, MrMike06, Msolem, muchi56, muddynoll, mustangsel, mx185sw, Mx_racer_36, New6.0PSOwner, nickPSD, nick_pebley, njjeep, NoBallz, nolimit, nos487, Notalent, notch86, novakid69, NRA4ever, nwb3160, nwstroker67, Nyofndremz, OBSdan, OH Roadbuilder, Ohnny101, OKState, onefaststang, opieg01, osthusna, OuchThatHurt, oxinthebox, papadelogan, pdizzleinmt, Peterbilt66, Plumbnman, Pollackz, porkchop, powermax04, powersmoker73, PowerStroke10-8, powerstrokejonson, powerstrokeracing, powerstrokin15, PowerSub, projectram, PSD POWER007, PSD-BLACK-CLOUD, PSDawg, pstk5088, Rawdag, rdunagan, rebel6.0, redhawk19, Redline7.3L, redneckabbott, redpowerstroke, REDSOX2758, redx, renyren, rfrostick, rmk900, rmkking6, roadstar, rob1232, rocketron, Rockyardjo, rollingthunder, ronnyz, ruckdork, rum4, Sapps, savvy1, SCDUCKMAN90, scott2001, scparrish, sdjohnny, secstang03, semmens21, sga6.0l, ShiftyCapone, Shobin, shreyshah1120, shvlhead78, SickStroke6.0, Sigster, sleeperobs, slimfitz, slippy, sly1types, smerleau, Smut, snbm97, Sniper32, sniper_101, southbend_powerstroke, SouthFlstrokin', southmike, spastik monkey, SPL2K, splitshot, ssduck30, stackedstroker, Stevenmc08, Steveo2001F250, Stroke00, stroke60, strokeman, StrokerSmoker01, Strokethis17, StrokeThis8, Strokin304, strokin340, strokinak, strokingkid1392, Stroking_Around, stuckinmud, stunu13, super73, superxcrewfx4, suprhlr, survivalsquid, svorob, Synyster, TAMU_PSD, tankersrule, Taylor0369, tcjohnson00psd, TerryS1980, texasbandit, TheSmokinStroke2002, thompson238, thoroughbred, timrgas, TireGuy, ToMorrow44, TomzToyz2, TonyW121, topshelf7.3l, Toreador250, toverbey21, true98jeep, turbodiesel_02, turbosi44, TxFire, ultra755, VaTechPSD, vcassens, vgk, villestrip, Vin6.0, waldroupa, wasted wages, Weatherlite, Whiskey River, whitjo, Wickky, widieseltech, WikedLizard, Wojo, xcessivebronco, xP12ODIIGYx, xsperf, xxxbrutusxxx, yhatzee89, yobuda, you smoke, younggeezer, zaairman, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
