I've had a couple people ask me how to change the nasty stock green interior lights over to another color.. I was just sending them to the website but that website is not up anymore.
I did this mod on a 99', 00' and an 05' a well over a year ago and I might leave out a couple things so ask questions and maybe it will come back to me.
First lets get some knowledge about LEDs. LEDs have a positive and negative. The positive side is called the anode and the negative is called the cathode. The negative side has the big terminal (anvil post).
Before installing the LED check it with a mulitmeter on the continuity setting, if you put the positive on positive and negative on negative it will light up. If you check it with a battery with out a resistor it will burn up.
WINDOW AND LOCK SWITCHES
The parts:
3mm LEDs (Pick your flavor) I bought them from
62/36/2 .022 rosin-core solder
Tools(after switches are out):
Set of small screw drivers
Solder iron
Set of solder tools (recommended)
De-soldering bulb or de-soldering braid
Squeeze clamp
Take the switch out and disassemble it. The button pops off and the rest of the switch unclips and then comes apart.
Grind the top of the LED down to diffuse the light in the switch.. If not the light will point straight up and will be a nuisance while driving at night.
After the switch is taken apart use a squeeze clamp to hold the switch in place while working on it, unless you have a small bench vise.
De-solder the original LED and replace it with the new.. Pay attention what side the LED is at when you take it off so you don’t reverse polarity.
When you have soldered the new LEDs take a 9v battery and put it on the power terminals to test it.. Or plug it in to your truck and try it out.
On forgotten.net’s write up he said to use a 5.6k resistor to replace the old resistor in the switch. I did not do this and not one led has burned out yet.
The parts:
Solder iron
Squeeze clamp
