I think thier is a good write up here on on the ORG, im thinking it might be on the org. maybe go over thier and scan through the stickys and search here and thier. From what i remember its not to bad, just measure and tape it off then cut it off with a grind wheel
if its chrome is 2" wide green painters tape on the bottom of the grille to cover the chrome, then use 3/4" wide blue tape and follow the bottom of edge of the grille all the way around and cut along the line on the upper edge of the 3/4" tape, test fit and trim if necessary
