i just bought a 02 powerstroke it has a 6'' skyjacker lift 20''s and 35's new ball joints new 1'' trac bar the tires wear even it drives straight as an arrow when u take your hands off the wheel but if you hit a bump in the road or brake hard or eveen just let off the throttle the truck is all over the road to the point where its dangerous. and the steering feels sloppy causing you to over compensate when u do try to correct it. anyone have some ideas??? thanks alot
first to get the best answers posting this in the suspension section would probably get you the most results. though i do think you should check your tie rod ends, if they have alot of play they tend to jerk the wheel on bumps and such.
I dont know how leafs spring trucks adress the front axle caster. Is that correct as well? I know this caused my truck a lot of headakes when ti was listed and I didnt have enough caster,
