I had 8" of lift on mine and didnt have any problems. I just had to pull the wire loose from the plastic fenderwell and drill a new hole for it. Here are the directions for the ICON kit. They address the abs line in step #3:
dont cut them. I ran 8 inches and didnt have to cut them. if you really are short they attache to the a arms with a little rubber grommet. Just pop it out of the bracket. May take 5 seconds total. I bet they are tight when the suspension is unloaded. Remmeber when theres a 7000 pd truck on top of it its going to compress giving the abs lines slack. just DONT CUT IT
the gromments will slide on the line as well with a little wd40 for lube. You can get a ton of more wire up by the caliper by moving the mounting gromments
