im leaking fluid out of my bell housing cover i hope not transmission fluid 96 f250 7.3 5 speed manual let me know what you think and how it can be fixed
crawl up on top of the motor and look down between the heads. Its gone be fuel or oil. Most of the leaks start up high and run down the rear of the motor.
I betting turbo gasket leaking oil down the back side of the motor. Rear seals and or 5 speeds leaking that way are more rare, possible but not as likely.
May be high pressure oil plugs in rear of high pressure oil gallery on the end of the head if not the above noted....
jrc
