first post on this site. i'm doing the 08/10 mirror swap on my 02 f250. i'm wanting to use the factory retangle connectors on my truck and just add more pins in the connector. does anybody know where i can buy some and what size are the pins. thanks
On my 03 F-350 when I put heated/lighted mirrors on it. I found a "Donor plug" at the junk yard. I removed the plug with wire left on both sides, and spliced the wires in to the harness. Inserted the pins into the plugs.
The plug is from a Ford Taurus or Mercury Sable. I found the plug under the hood. Not sure what it was, but it was part of the engine harness.
i found some male pins for the connectors. they are called ford wedge lock pins. i couldn't find the female end of the pins. i ended up buying 2 plugs with the female ends. thanks for your help guys.
107.5K members
