i have purchased a 8in basic fabtec lift will i need any special tools i bought a pitman arm puller already... and i bought dual steering stabilizers will i leave the stock one in place? it didnt really say in the instructions..
Don't need a pickle fork. You can use the pitman arm puller (which most likely will need the latching tabs to be ground off a bit to make it fit ove the pitman arm) on the tierod ends if the hammer trick doesn't work. Pickle forks will damage the rubber boots on the tierod ends.
my pit man arm is too small i need to get a dif one. and i hit the arm that goes to the pit man arm and i cant get it loose... i did soak everything in pb blaster weeks before i started lol.. i also need to get new alinment pins for the rear springs.
