finally starting to make some progress on my project, engine together, trans done, twins mounted, need to do all the piping. long ways to go but making progress finally
Just a hint...get a oil filter relocation kit. With compounds on these things you can barely see the oil filter much less reach it to change it out.
Amsoil makes a very nice dual bypass kit where the lines go on a head that screws on where the stock filter goes.
I'm super glad I sprung for it on mine.
the motor is a 04.5 it has exergy 40% over balanced injectors, headstuds, #110 valvesprings, colt/hamilton183/220 camshaft, 2 gen stainless diesel exhaust manifold w/a 60/68 over a s475 billet wheel twin setup. dont have an injection pump yet but probably going with a 85% pump.
the 7.3 windowed while towing :doh:
Looks good! Ya I'll back Unbroken on the oil filter relocation kit, I am running Destroked's kit. I can hook you up on one if you like, got them in stock!
nah...you're just right for towing. It'll be absolutely perfect for that.
Against my better judgement I bought some 90% over injectors and a dual CP3 kit. So much for a reasonable daily driver. LOL
You're gonna love it when it's running though...there is no comparison between the 2 motors.
update, trans and transfercase (271F) is mounted in the truck with the crossmember and mount modified. 4x4 shifter mount made and all working properly
my question for those who have done this is with the 48RE is how did you make the shift cable work properly? the lever on the 48RE has a different length than the 4R100 ( I think I have that part figured out ) but what did you do to mount the cable
I bought the truck new in 01, it has never seen winter. It has to date 35k miles on it, I dont even drive it in the rain if I dont have to. it had better be cleanLOL
I got the shifter cable bracket done and working good, front & rear driveshafts shortened/ lengthened, throttle adapter linkage from destroked in, and all good, power steering pressure hose and adapter line made just need to run return lines from cooler and hydroboost to reservoir. destroked tach pickup and tone ring is on. still a long ways to go but making progress
got a few more thing done, power steering lines and returns done from cooler and hydroboost
battery box done
bottom charger is finally mounted in truck in proper place to start building the hot and cold pipes. I have another bare block and head on the stand to build from to make this a little easier
battery box done
I've had lots of discussions with Chris from Engineered Diesel and we decided this was going to be the best setup for the truck with what it is going to be used for, mainly towing
