Even when lifted if the steering is addressed properly you will have zero bumpsteer. Any pics of the front of your truck? The suspension and steering components at least?
I have the icon dual steering dampner setup on the front of the truck.
Il try to take a picture later, but when looking at the linkages from the front, I would need to drop the upper pivot point of the trac bar to get it to be parallel with the steeing link.
Assuming the frames are the same, maybe there is a difference in the steering boxes or the pitman arms between the leaf and coil sprung trucks.
Heres a pic of the front end. What are your thoughts?
Caster is 2.2 on the left and 2.3 on the right, I believe from when I had it aligned. It has the icon cams.
