My truck will be spending some time in the body shop here in the next few weeks. While it is there I thought about having them install the 38 gallon rear replacement for me.
I read a good deal about this mod in our library and found the comment that we can use the F26E and the info I found on the web tells me that the tank is not for diesel fuel. Is there 2 versions for the F26E? Is there a kit that can be bought or a parts list I can get?
I just did the 38 gallon tank swap a few weeks ago. Buy the F26d, it is cheaper and literally takes 2 minutes to pop the vent out of the filler neck and its just like the f26e otherwise.
no lower than my hitch....unless you know what its supposed to be you wouldn't be able to tell...that said, I have not put my spare back under there yet, so? it may hang a little low, but not as low as the axle of course....so, we'll see.
Cat about half of what the Bronco tank does. I got my 38 gallon tank out of a 78 F350 camper about four years ago in a junk yard for $50.00 and then $60.00 more for cleaning and sealing.
exactly, its less than 8in. deeper than the factory unit, and the factory unit is even with the bottom of the frame rail....also the spectra tank comes with the bolts and spacers needed to drop the skidplate to hold it. I used a compression fitting to extend the pickup tube and I bent a new float wire out of a piece of coathanger...the instructions that came with the tank had you extending the tube that holds the float unit down, and thus leaving you with a full tank for half of it, and then your gauge will move the last half....I didn't like that and made a new wire to show full sweep on the gauge for the entire tank full.
all told, maybe a couple hours actual work to swap it, however I took the easy way out and had the bed off because I was also installing a gooseneck hitch and removing some old bracketry from a previous owners 5th wheel hitch.
A 4x4 installation will be slightly tricky in that they have that hideous design with no actual straps holding the rear tank; it's just held directly by the skid plates. Inevitable result, crud builds up in between them, tank rusts through. So if you go with the straps for the 33 / 38 gallon tank, you'll need to fab something up with threaded rod or the like, in order to hang the skid plates. If you do it right, you'll hang the skid plates with aprx. 1" between them and the bottom of the tank, so there won't be any way for the rust-o-genic crud to build up.
Do you have any pictures of this that you have done? This is what I have planned but with little time I will have someone do it for me and it is much easier to show them a picture than explaining what has to happen.
I have not found a parts list/kit for this mod. Do you have something I can get from you or someone else? I would love to get my hands on a parts list or kit. It sure would make it easier to just hand over to a shop.
This is what I found on Rockauto. Is this the right tank that ya'll have used? Much cheaper than what I had found - thank you very much.
While this is being done I want to make sure and get the correct fill tube/hose so that I am not back there holding the pump for half an hour filling up. What did ya'll do for this? Thanks a lot for all the help - this is what I was looking for.
So if I buy this F26D from rockauto do I need anything else to install it? My rear tank is leaking bad and needs to be replaced. Compression fitting ant tubing to extend pickup, coat hanger for new float arm. Do I reuse the sender in my old tank? I just want all the stuff I need so I can just pull out the old and install the new. Thanks!
I painted my tank with 3m rubberized undercoating prior to installation because it comes bare. I can't remember the size compression fitting you'll need...i just rand down to the hardware store when I had it appart to get the right size with the tubing in my hand. Yes, you reuse your sending unit, thats what you'll need to extend down for the pickup.
Other than that you should be good.....in order to do the fast fuel filler mod, you will need to remove the filler necks from the truck, remove the long black plastic inner tubes, remove the metal reducers from the top of the neck.
take out the plastic roll-over valves on top of the tank and drill them out to accept a 5/8 hose barb elbo, JB weld that is, then drill into the metal filler neck and jb weld in a 5/8s hose barb to that as well and run a 5/8s breather hose from the neck to the rollover valves....there is a write up by DizlJim that is very helpfull in this. After completion I can now fill my tanks on full blast of the regular (non-18wheeler) nozzles.
man, two 38 gallon tanks would be sweeeet! so is there any science to bending the coat hanger for a new float? that would be my fear is jacking up the reading of my fuel gauge
Not really any science, just be careful when installing and removing the float off the unit, you'll see what I mean when you get it out and look at it....I just took a pair of vice grips and a pair of pliers and took my time. I used the original float wire as a pattern, just making one section longer....I actually made two, cause the first one was too short, go ahead and extend the pickup down first and then play with it and see how long it needs to be.
When I had mine made I test fit it in the tank and it was slightly too long because when it was sitting in the tank with no fuel it was just above E, so I bent the wire a little and it went to where i wanted it to on the gauge, tested it again full just to make sure.
It will make a lot more sense when you get it out to see it first hand.
thanks for the tip, that gives me some confidence to do it, having a bigger tank will be so much nicer on the long road trips! anybody know if this tank can be used up front as well?
I believe the F26E came in the late '80's trucks, like a 1988 F-350.
I mounted mine using the stock skid plate not straps, and I also mounted the spare under it by extending the hanger mounts with some pipe.
I seriously doubt your lcoal parts store will beat the price from RockAuto even shipped to you.
600 miles on the rear tank in the summer, about 825 mi between fill ups.
Winter sucks, I can squeeze maybe 500 out of the rear and 150 out of the front.
I got the F26D tank from RockAuto and It's a VERY NICE kit for how cheap it is!!!
I'm having trouble breaking the vent tube out of the filler neck, mine must have a good weld on it....Do I need to remove it or can I leave it in there?
Thanks !!
Put my filler neck in a drill press vice and used a hole saw in the drill press to cut it out. I guess you could if careful, use a the hole saw and cut out the vent restrictor while on the truck. You would not want to have the fill hose hooked up because of metal chips and flakes. Just go slow and it should work I also used cutting fluid to cut easier. It will fill faster if you cut it out. Just so I am clear here are we speaking of the filler vent in the elbow? The vent tube in the filler hole on the F26D tank, iirc I just left it in there. I tried to twist it out but broke the whole neck out of the tank. Had to re-solder it in.
I opted to enlarge the roll over vent using J B weld, a brass street elbow and some other odds and ends to replace the in hose vent system.
Guess I was too aggressive as I used V grips and it broke the entire neck out of the tank....hahaha. Got out the torch solder and paste....and I just left the vent fitting in place.
so. The poly tank from bronco grave yard is not as good as the steel one? Seems like it would be better? Next. Do you just slap a draw staw into the top of it? And run a return line? ditch the front tank. Because my cummins swap Is going to need a good bit of fuel.
The plastic is a benefit to the bronco tank but the dimensions of the F26E are much better plus 5 more gallons capacity. With some spray bomb coating, the steel tank might outlast the truck at this point. I wiped down my steel tank with Acetone, used Scotch brite to rough up a little, wiped again w/ acetone(USE GLOVES!), Primed and Painted with Lowe's-Rustoleum bedliner spray.
My original 16 year old metal tank didn't get this good of a coating and it was still ok....
I like your Cummins swap idea, I wish I had done that a long time ago with mine !!
Yeah, draw straw kit from Airdog.
The Tank is the same Gas or Diesel trucks...all metal, nothing to eat up, just the "D" model has a vent tube in the neck.
You reuse your stock stuff and modify the level sensor by extending it a couple inches with some welding rod or wire you have laying around.
