Wheres the best port to use for Oil press gauge? What size fitting is it? Ill have to pick up a threaded plug so i can mate the plug on my guage up to it.
What are normal readings?
Idle..?
Hwy speeds...?
How low/high can it go before causing damage?
there is port on the filter housing and on the same side as the filter i used a port thats right on the lip of the bell housing where the trans and motor mate..if i remember right my sendor that came with the auto meter went right in...
when up to temp i read 25 at idle and 40 under load.... they will read higher on a cold motor..
My gauges were a old set i had rolling around in the bottom of my dresser. Got a few pieces missing.
Thanks
