Just got this official notice!
Stealth SRP1 Pumps
EVERTHIHNG ELSE IS JUST STOCK!
Stecher Performance LLC. Would like to formally introduce the new Stealth SRP Stage I pump to you. This new pump has been in development for over a year now and is finally ready for release. The Stealth SRP1 pump is designed for the 94.5’ to 03’ 7.3L and 03’ to 04’ 6.0L Powerstroke engines. The Stealth SRP1 pump is a “Stock Replacement Pump”, SRP1, that will give you Stage I performance in a stock pump housing! We have addressed all of the stock HPOP housing flaws while at the same time increasing internal displacement by almost 50%! This is an increase of over twice the displacement that our competitors are offering in their pumps! These new pumps have all new internal components for a reliable operation. Inside these new pumps there are all new larger billet pistons combined with a new 18-degree billet swash plate that still retains stock reliability while increasing displacement by almost 50%! With the new larger pistons and new swash plate we have managed to increase displacement to 10.45cc vs. the stock 6.8cc or 7.2cc pumps. All pumps are designed with dual ABEC-5 ball bearings for added stability during operation instead of a rear bronze bushing like the stock pump late model pump uses. All of the snap rings, o-rings, and seals are new. We have machined the 3 high-pressure output ports from #6ORB fittings to #8ORB fittings resulting in twice the thread surface area, which means no more stripped or blown out fittings. We have also machined the edge filter plug in the bottom of the pump and taken it from a #3ORB fitting to a #6ORB fitting resulting in twice the thread surface area. We also machine some of the internal passages to ensure proper flow in and out of the pump. These new Stealth SRP Stage I pumps housings are bead blasted and coated with a ceramic base high temperature paint. The front mounting gasket surface area is re-machined flat to ensure a leak free installation. All of our new Stealth SRP1 pumps are rigorously tested to full pressure and full rpm on our test bench for 30 minutes to ensure optimum efficiency and performance before they leave our shop. The Stealth SRP1 comes with everything listed above and is also covered with a 1 year unlimited mileage warranty
These pumps will be ready to ship within two weeks from this posting. We will need full payment for the pump up front due to the limited quantities on this first batch of pumps. Pictures will be posted as soon as I get them:thumb:
So anyone thats been waiting to place your order now's the time..Please PM me for pricing and payment details..
Thanks, Cary
Stealth SRP1 Pumps
Thanks, Cary
