-Custom compression ratio's with or without valve relief's.
-Ceramic coating material added during the forging process which embeds into piston up to .001" for longer piston life.
-Available in standard, and over size bore
-Comes with rings and pin clips.
We have been using a similar piston design and coating process on the duramaxs for the past few years and have seen huge success from the daily driver application all the way to full out race applications using LARGE AMOUNTS of Nitrous.
Attached is a picture of a duramax piston to give you an idea of the quality of piston we are offering.
First order of pistons will be arriving within 3 weeks.
$2650 for the complete set for your common compression ratio and bore size.
I would be willing to bet those pistons aren't made anywhere near USA. Most US based companies have no choice other than to outsource bevcause this as with many markets are so whored out that you can't stay competative enough to sell to mainstream manufactures such as ford, powerstroke, international.
Hell there's guys on just a tune cracking pistons. If anything it will make for a bullet proof bottom end.
