Most 4-5" lifts either use a trac bar drop bracket or an adjustable bar.
FWIW, the axle on my 07 stock with 6,000lb coils from the factory was pulled over to the driver's side. I swapped them out for 7,000lb coils which lifted it 1.25" or so and put the Icon adjustable bar on at the same time.
If like me the OP is anial over a 3" lift needs the drop bracket..if not correct add a adj bar.
Drop pitman..once you get to 4" as std ones start at that point, custom ones made for ea exact lift..haven't see any.
