I did a little searching and didnt come up with much. I need to put a new input gear in my transfer case and having a heck of a time splitting it. Is there more to it then just removing the center bolts? Any pictures or knowlege would help.
Thanks
To get the case apart you need to pull the front yoke off, remove the seal and you will see a snap ring, it needs to come out also. that will allow the case halves to come apart. just make sure you lay the parts out in the order you remove them, makes it easier to reassemble. It's not to bad once you get it apart.
