03 6.0L oil drain holes? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 10-24-2010, 02:50 PM
Critter62675
Offline
Member's Gallery
does anybody have a diagram of these holes? Replacing injectors and need to know what holes to plug with towels? I have holes in the top and the bottom. Thanks, Craig
Reply With Quote Quick reply to this message Go to the top
Old 10-24-2010, 03:36 PM
matty169
Offline
Member's Gallery
Re: 03 6.0L oil drain holes?
What are you talking about? Pull valve cover, stand pipe, hpop rail, and injector. Lube O-rings on new injector and install. Torque to 26 ft. lbs, and put back together. Bump starter over several times until all is clear and then crank away. No plugging anything with towels here. Got a dremel tool? Use that wrench for changing bits for the hose on the hpop rail.
  #3
Old 10-24-2010, 03:55 PM
Critter62675
Offline
Member's Gallery
checking because manual and internet say plug these holes so nothing falls in them and so you won't have to take off head. There is 2 holes one above the injector and one below the injector bracket. I just don't want to have to pull the head.
  #4
Old 10-24-2010, 03:58 PM
turbodiesel_02's Avatar
turbodiesel_02
Offline
it's an 02 05 08
Member's Gallery
just be very cautious espcially on the passanger side,the rags will get in the way in imo
__________________
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
  #5
Old 10-24-2010, 03:59 PM
Critter62675
Offline
Member's Gallery
Thanks, but gladly I just have to change #6 and #8 on the drivers side.
  #6
Old 10-24-2010, 05:03 PM
turbodiesel_02
Offline
it's an 02 05 08
Member's Gallery
you lucked out,thats the easy side
  #7
Old 10-24-2010, 05:09 PM
Critter62675
Offline
Member's Gallery
So does anybody know what the holes are below the injector bracket screw?
  #8
Old 10-24-2010, 10:14 PM
turbodiesel_02
Offline
it's an 02 05 08
Member's Gallery
i believe drains the injector holddown torx screw wont fall out of the hold down
  #9
Old 10-25-2010, 03:27 PM
Critter62675
Offline
Member's Gallery
Does the oil go from the oil drain holes in the head to the oil pan?
Human Verification
(View-All Members who have read this thread : 32
04 hotrod, 2006nytro, bad moose, BBowden73, Big Papa 03 dually, buggut, Critter62675, dag4566, demented_diesel, DieselStroke, flyboy41, flybykota, halerazor, hawgdoctor, hill_billiez, Honda30, Ignorant1, irontx25, jaxral, JD F350, Jingoist, kenny7231, lilredrocket, matts05f250sd, matty169, pccurr, RW_Kaspar, Super_Dirty_06, tsedsell, turbodiesel_02, Wheels
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
