what all do you have going on there? I already see something that I want to change on my truck... I see you have a full lift leaf spring and I have big ass blocks. so thats a thing i must change.
The rear is comprised of 5" leafs with a 1" block, and Signature shocks. Additional components are OUO Adaptable traction bars with bolt on bracket for the axle, and Firestone Riderite air bags.
The front is 3" hanger/shackle, 4" leafs, signature shocks, adjustable tracbar, dual steering damper, and box kit (drop tracbar bracket, drop pitman arm, longer swaybar end links, bumpstop spacers)
well can anyone at least give me an idea of what size lift I have?
those tires are 37" toyo MT
When I bought the truck I guess it was a mistake not knowing more about the lift. though the engine works great and so does the suspension but not sure what it is... 6" or 8" it has blocks in the back. i believe its a tuff country which I plan on getting a new lift for it, but want to know if I should replace with 6" or 8" or if it makes a diffference.
what is the major difference between the 6" and the 8"? for instance if I have a 6" and I bought a 8" would it pretty much be the same hardware and no extra parts? IE driveshaft, angle of the rear diff?
Betaracer, we have the same tire size and wheel size so i must be either a 6" because yours is a bit higher than mine... especially in the front.
