I have a friend of mine who has a 95 with over 300k on it. He's replaced 2 injectors, and put all new o-rings on the rest of them. Now for some reason the oil won't get primed through the high pressure side. If anybody has had a problem with that, and the HPOP wasn't the problem, let me know what their culprit was because he needs his truck to run. In that case, don't we all.
those injectors could be wore out at over 300k,or the lpop could be worn and not feeding the hpop
you may get a better response in 7.3 tech section also
It is an oil drain back issue common to the 94.5/95 trucks. Is the hpop resevoir full? If not refill it. Also you need to watch where you are posting threads as this is the suspension section.
I had asked him about the o-rings already. He worked at a ford dealership mainly on diesels so he'd rather do it himself. Thanks everybody for the ideas.
I'm sorry about posting that thread 3 times. I'm trying to do this on a blackberry and its not exactly cooperating fully 100% of the time.
