Just bought a set of 18x9 rims with 4.5" backspacing. Wondering what would be a good tire for this combo, on a 06 f250 fx4. Looking at the 325/65/18s Nittos or the 305/65/18 BFG All Terrains.. Will both work without rubbing? Dont want to order either one without some input. Thanks in Advance.
The truck looks to have a leveling kit in it, if not Ill put one under it no problem there. Another option is a 305/70/18.. this may fit? Anything you would suggest for it, the current tires are 275/70/18 on stock wheels, which work out to around a 33x10.5, and they seem to have a ton of room for a couple more inches.
If you have a leveling kit on, or put one on the 325/65R18 may work. But it may be a little tight.
Either of the 305s will most likely clear better being 20mm skinnier.
