powerstroke smoking/hazing at idle - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 10-04-2010, 11:40 AM
NAZTY 4X4
Offline
Member's Gallery
I have a 2000 F350 7.3L with the mods in my sig. I noticed about 1500 miles ago the truck hazing/smoking (whitish color)at idle cold or warm. All my gauges are reading properly. No fuel leaks. Truck runs properly and sounds good. Truck looks like a hoopty at stop signs and signals when it is smoking/hazing.
__________________
2003 F250 4x4 SCSB lariat 6.0L auto, 4" lift, 35" nittos, sct tuner with IDP tunes, S&B intake, Power max turbo, blue fuel spring upgrade, fass fuel system, fs2500 oil filtration system, arp head studs, egr cooler deleted, bd exhaust brake, 4" stainless steel exhaust, gogo shift solenoid, ats deep trans pan, mag hytec diff covers, isspro gauges
Reply With Quote Quick reply to this message Go to the top
Old 10-04-2010, 02:27 PM
SeeYa's Avatar
SeeYa
Offline
Sponsor
Member's Gallery
Re: powerstroke smoking/hazing at idle
Have you ran a Contribution test on the injectors? White smoke commonly indicates unburnt fuel most likely left over in the cylinder after shut down. Even when the truck warms up to operating temps you say it still does it?
__________________
Diane @ DP-Tuner
828-221-0076 x 802
  #3
Old 10-04-2010, 11:02 PM
NAZTY 4X4
Offline
Member's Gallery
yea even when it is warmed up! Injectors have about 2500 miles on them. They were replaced 2 months ago.
  #4
Old 10-05-2010, 01:01 AM
CTFFEMT
Offline
Member's Gallery
mine does too. subscribing...
__________________
2000 F250 7.3 PSD ZF6 4x4.
  #5
Old 10-05-2010, 02:31 AM
apollyon9515
Offline
Member's Gallery
Who replaced them and what were they replaced with? could be another bad inj or maybe a oring got cut during the install. I would listen to jody/diane and hook it up to a AE or some type of scan tool.
good luck, mines doing the same thing but im 99% sure its low compression or a bad injector and plan to find out soon.
__________________
2001 BTS trans, AIS, coolant bypass filter, CCV, 4" to 5" exhaust, PMR's
http://www.DieselPowerProducts.com "Powerstroke Performance Headquarters!"
  #6
Old 10-05-2010, 03:53 AM
hdchopfather's Avatar
hdchopfather
Offline
HD550FORD
Member's Gallery
mines doing it too,only at first start up,once its warmed up it stops,normally first thing in morning,i was thinking bad injector...
  #7
Old 10-05-2010, 11:18 AM
NAZTY 4X4
Offline
Member's Gallery
me and a buddy put them in and he has done them before, he knew all the little tricks. I got the injectors from full force diesel, they have a warranty.
  #8
Old 10-05-2010, 11:39 AM
mattr66's Avatar
mattr66
Offline
Snake Oil Salesman
Member's Gallery
Does the exhaust smell like kerosene or nasty burning oil when it is hazing?
__________________
Matt Robinson
Gearhead Automotive Performance
Information on My Ford Tuning (Gearhead Automotive Performance)
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
  #9
Old 10-05-2010, 11:58 AM
JLDickmon's Avatar
JLDickmon
Offline
blame the dog..
Member's Gallery
Well, the little trick we techs use is:
you did something to it, and now it does "X"
so go back to what you did and start there.
In this case, I think you're looking at pulling/visually inspecting the injectors & O-rings.
Don't just sit back & speculate, pull them and check.
__________________
This site needs new newbs.
  #10
Old 10-05-2010, 04:33 PM
apollyon9515
Offline
Member's Gallery
Matt mine smeels like kerosine or something god awful, im assuming its a bad injector/oring and fuels not getting burnt all the way. Hoping its not a cyclinder, ill find out this weekend.
Human Verification
(View-All Members who have read this thread : 136
00POWERSTROKE777, 01REDSTROKER, 02black7.3, 2000XLifted, 2006nytro, 4duggan, 7.3powerstroke03, 710_burner, 79jasper, 84crewcab, 907DAVE, 97F250 HD, 99STROKINSMOKIN, abbottfarms, adventr, AK1, All Stroked OUT, apollyon9515, badford350, Barnbuilder, BDP Tuner, ben02stroke, birdog, blacksport03, Blowby, boostaddict, Bulldog, Bushwakd, camaroicoc, CARR, cj45lc, copperhead99, Crazy Canuck, cre440, Critical, CTFFEMT, Cutty72, David N, DEVIANT, dezl, DHTD, DieselBrad, Dieselgeek, Dieselsvt, dirtboy25, DMDP, dmschmidt1200, dmstrucks02, Dog86, Duanesz, Erle385, F-127, farm boy, farmall99, fast92gsx, FordSuperDuty05, fyrehose, glovemeister, golfer, greenbeast, Greg, HaysKSFirefighter, hdchopfather, hienergy557, isky1843, J HO 22, Jbgabriel, JBmaker, jdecker88, jeenyus73, JLDickmon, joediesle, Jolo170, ju015dd, junior125, Kampy, Keaton, krankin, kvn555, kyle@DI, lopp, madmaxz, Mark J., Mat J, mattr66, merlinnilrem, mflores, morefuel, mp350, mrit, Myles_S, NAZTY 4X4, NRHX2009, P-nut, Phiber Optik, PHPDiesel, Pipewhiner, PowerstrokeR00, Powerstrokin96, procomp, PSDfan99, raformula, ralph, ridiculously_necessary, Rmartin-97, rpm-inc, San Antonio 78, SeeYa, semomotorsports, silverslug, Smoker00, stackedstroker, Stonepusher, Stroken7.3, stroker2, tallpaul, tecster, theoldgirl1990, tholt34, thompson238, tims02ford, toddg, toolmangary, tree trimmer, tunerGONEbomber, Walt6488, Wayne64SS, WichitaF250, Wickky, woodduck97, wooner
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
