I'm putting this here because it fits better than in the '94-'97 General aftermarket.
Since last night I grenaded a u-joint in my rear driveshaft I'm looking to get larger ones on both ends for insurance reasons. The front of the '96-'97 is a flange style like the SD's use and the rear is a yoke with straps.
Are there factory SD parts that I can use to upgrade on the front then have the driveshaft changed or remade to accept larger joints? I figure my biggest problem would be finding a yoke for the Sterling 10.25 to accept the larger joint, but then there might be something from a Sterling 10.50 that will work. I'm not sure, I figured I'd check here and with the local driveline shops.
-Michael
-Michael
