On the drivers side front of my truck the top of the tire is leaning in i have taken it to every mechanic in town and they have yet to find a problem. there may not be a problem but something dont look right because the passenger side is straight as an arrow
what would you guys do and do you know the problem
most likely a camber problem did you take it to a cheap alignment shop? some cheaper places wont mess with camber so have it checked (that is the in and out of the tire) also have the ball joints checked however if they are that bad you would know as they would be falling out!
If everything measures good, it might be an optical illusion caused by the axle being pulled towards the driver's side if an adjustable tracbar was not used.
