I have a agr rock ram hydro assist kit on my 03 f250, it has been nothing but trouble for me and i was wondering if anybody else has had problems with agr products. What kind of hydro assist kits do yall run and have had good luck with?
Its the agr rock ram system with the ford super pump (agr super flow power steering pump) that runs the stock steering gear box, the ram is a .75" single agr rock ram. The problem i keep having is the seals go out on the pump after 1500 miles and leaks power steering fluid. I have contacted agr repeatedly and the apparently do not make the super pump for the 7.3 any more and the past two i have ordered through summit racing have had to be made by agr.
Do you have your bumpstops and ram set up so your ram is at full extension when it hits the bumpstop. Then when it is retracted it is the same way. Otherwise you might put some extra stress on everything...
