I got a call from my girl friend this morning that her truck was running rough and she wanted me to bring her the car so that she was sure that she could make it home. So I went and picked up her truck and stopped at the shop and put the scanner on it. It looks as though #4 injector took a crap on it and will need to be replaced. We have put about 10,000 miles on it since we got it and this is the first problem we have had with it. I have been been changing the oil in it every 4000 miles with 5w40 synthetic and putting motorcraft or international filters on it. I changed the fuel filters on it shortly after we got it. I guess it is time for an injector and possibly a egr delete. So much for getting a tuner for it this time around.
A long T45 torx bit makes getting the injector hold downs a TON easier.
Take a picture or mark where the studs go on the intake manifold. If I recall correctly the only side that really matters is the passenger side where there are 3 different length bolts/studs. This may be model year related, so just mark em and forget about it.
Also if you mark it with a sharpie and then run it through a parts washer, you won't have anymore markings LOL.
Check sinsters website. They have intake gaskets on there for super cheap. If not there check ebay. I got gaskets and turbo mounting hardware for 52 bucks shipped to my house on ebay.
I doubt it the guys behind the counter at my IH dealer are lost if you dont have a serial number or a part number. I will do a little digging and see if I can find it.
Well i stoped at international today and picked up an injector and a intake gasket set. They had the pest prices around for injectors so i decxided to go that route. I will get some part numbers posted up when i get home and have time.
