I have a 2006 ccsb F250 with the auto lock hubs I am getting a popping noise when I hit the brakes, accelerate hard, and some times turn and I went to use my 4wd the other day and my vacuum isn't working and my ac is blowing out of my defrost when I first turn it on but I can get it to blow out of my regular vents if I turn it to 1 and then crank it up once it get blowing I had it looked at by a 4wd shop the said my ball joints n tie rods are shot all the way around especially my driver side which is what's making the most noice because they said there was so much play in the front wheel I am kinda leaning towards a hub or bearing issue though the truck is lifted with 38's but I only have may e 10k on since the lift and the truck has 74k all together any thoughts?
