I am thinking about ordering a leveling kit off ebay and am not sure if it will works. Its a Summit Engineering 2.5" leveling kit, which basically are 2 round blocks that olt to the bottom of the axle through the spring cup. Does this sound correct? never done one before and want to make sure i get somehting that will work.
I would just buy a good leveling kit, like the one from Icon. You need alignment cams and an adjustable trac bar, otherwise your axle will be off center and your caster won't be correct causing the truck to wander.
Also looking for a leveling kit for 00 350 but I don't believe this style will work as I have leafs in the front and not springs....???
