okay you guys helped me with my turbo. now I need to find out what is causing the clicking noise when I turn left or right . It is not that loud but it is getting worse. My hubs are not locked in . I dont use 4x4 alot if that matters. Any suggestions. thanks
sounds familar,i just replaced my track bar ball joint that was making the same noise,i got the part threw Ford,PART NUMBER MCOSE-51, my truck is a 05 i also replace my drag link also, u will been a good ball joint press to remove the track bar ball joint, if it is not this it maybe your steering box
107.4K members
