can you run bb code injectors in 99.5 superduty ? if so are they bigger than stock ad injector i only ask because i have access to alot of these for free thanks
I believe different people on this site have different views on that. Some say yes and some say no, with the amount of oil they use I wouldnt run them.
"BA, BB, and BC injectors are essentiall all the same and are the same as AC injectors but are found in some DT466s"
"All DT466s and I530E injectors are B codes. Of those some DT466s and all I530Es have a 7.1mm plunger, hense more fuel per mm of stroke, with a 17.5mm intensifier piston. This gives you approximately a 6:1 ratio. So no it will not have quite as high of ICP as as the A codes but it's not as bad as it could be. However due to the larger intensifier piston they reqire much more high pressure oil to make the piston stroke the same distance. This is why you need a high pressure oil system with a higher capacity."
107.4K members
