Hey everyone,
I need suggestions on what to do. I purchased a used icon 4.5 kit for my 06 F250. It was supposed to come with everything less the adjustable pan rod bar. Like a knucklehead, I didn't check every part before buying it. Turns out its missing all types of sh$t. The blocks aren't even icon. I think they're F350 stocks. Anyways the correct icon parts I have are:
Radius arm drop brackets
4.5 Coils
Front and rear shocks
Bump stop spacers
18” U-bolt kit
To make complete I still need:
4.5" Box Kit (less the bump stop spacers)
Adjustable Pan Rod Bar
Correct match rear blocks
And I'd like to add the 1” TEI spacer.
My issue is that Icon parts are crazy expensive. Just to get the above items is like $760. Plus the $400 I payed for the kit. Thats way more then I want to spend for a lift. Especially a 5.5” lift.
So with that....
What's my cheapest way to make this lift work? I just want 4-8” of lift on my truck. I don't care how I get there so long as is works. Can I mix parts from other companies? Maybe that would make it cheaper? Icon claims the pan rod bar is necessary. Is it really or is there another way around it? What about adding a cheap coil spacer instead of the TEI?
Thanks for any help!
4.5 Coils
Bump stop spacers
18” U-bolt kit
So with that....
