Jeremy, you really gotta let me know before hand when and where Guy is pulling. If I don't get out and see this thing pull at least once this year, I'm really going to hate myself all winter long.
It was 3rd place. I think first was 319 and Guy pulled 311. He needed newer tires on this track and ones like it. Was just really loose for what we are used to. Guy also got out of the pedal at about 50 feet as he got into the rev limiter and thought for a second that it was the clutch slipping. When the clutch slips some it will get really hot. At the end of the track there will be very little "pedal" left. 1" of the floor and the truck is moving again. It won't disengage enough to allow you to get the truck into reverse. The only gear that you can jamb it into is 4th. So you can see how easily that Guy backs up to the sled after the run so I knew he had no traction.
