I have a 2005 F250 with stock 17" rims. I'm considering buying 20" stock F250 rims and ties as a set. Do I neen a lift kit or am I ok with slapping them on??
Depends what tire is going on. Rims just need to fit over the brakes (and back space needs to work too, but not an issue in your case) and since 20" is larger than 17"....
The tire diameter and width will govern if a lift is required.
should be just fine. i fit 35 inch tires on my stock 20 inch rims with no modifications at all.
