I have an 04 f250 ext cab sb, i have a 4" lift with shackle on it, it already has drop pitman arm, drop track bar bracket, and traction bars, i purchased 8" front springs, 6" rear springs, shocks, adj track bar, extended sway bar links, what else is needed if anything to make it work? i saw something about extended steering coupler, stainless steel brake lines, and carrier bearing drop bracket any help would be appreciated
you will need a bigger drop pitman and a bigger drop track bar bracket (unless the track bar is adjustable)
longer shocks will be needed
drop carrier bearing can be done by 1/4" drop per 1" of lift over stock.
