Got the pass. side spring off. The front bolt on the driver side will not come out. Its frozen to the bushing, when I try to turn it the rubber just gives. I've tried putting pressure on it and beating on it at the same time. Sprayed it with penetrant. Should I use a sawzall and cut the bolt?
