well here is my deal. here about 6 months ago i swirved off the road to miss a deer. when i did this i hit a 2x6 with the drivers front wheel. big bang pop what not. after that everytime i put it in 4x4 it would grind in said position. so right there i knew i needed to fix it something??? well now im getting the same grinding noise all the time. i recently had the front end rebuilt bushings, seals and related parts. but i still have a problem up there im assuming that it is the cv shaft but im not real sure i havent torn it down yet because i have been so busy but i guess my ? is where should i start, or what should i look for. i should also add that the front wheel bearings are new on both sides...sorry for the long post but i wanted to try and get enough info so you guys could give me the best advice possible:ford:and thanks in advance
