my buddy gave me a gal of MAG Marine TC-W3 2 cycle motor oil, it's from Wally World, it doesn't say ashless on it. is it o.k. to mix this with my diesel fuel? if so what ratio.
i used to run diesel kleen every tank with 2 stroke but after reading some test results i believe diesel kleen every tank is a waste of money(overkill) ! i have been running 2 stroke every tank for over 2 years now with zero problems !
Puts lubrication back in the fuel, since this new ulsd has none....Quiets the injectors down as well. Some say a little better mpg but I don"t know about that.
Thanks. Does anything in the PSD fuel system need lubrication? I run either 2T oil or powerservice in my IDI, but its got that old mechanical stayndyne pump that definitely likes the lube. I guess I figured that the injection system on the PSD's didn't rely on lubrication from the fuel (but I'm also new to psds).
My IDI does get slightly better (but consistently so) mpg with powerservice in the fuel. Its just enough that I save just a little $$ by running it IIRC. I haven't check mpg with 2t oil.
