I have a problem, I'm about to put on the frame mount for my traction bars that i built. I mocked up the frame mount where the eye of the joint will be even with the carrier bearing. I cut the bars to length and mounted them to the axle mount. I was planning on putting the frame mount on the rod end and then welding it to the frame so that both sides would be perfectly even. I hope your following along.
Well, on my drivers side the sway bar is just low enough to where it hits the bar and i cant go up any higher.
My questions are:
Can i cut the sway bar links and shorten them about an inch so it pulls the sway bar back up? Or would it be better to remove the sway bar completely?
In 1 1/2 years i've had a trailer hooked to it once. If i remove the sway bar can i still tow with it? I don't plan to but if i do what will happen if i don't have one?
If you have better suggestions, shoot them at me.
My questions are:
