had a pretty good run. should have downshifted at the end but i wanted to see if it would spin out in 3rd w/ the 4.56's. also forgot to turn the pump on for the w/a ic:doh:, it actually boiled all the water out of the ic and was steaming out the ice box
Yeah and if your on the street and don't have ice in it, make sure you run the pump anyway. When Jon was here looking at my truck I kept the pump running almost constantly and after every other hard pass I'd make on the street it was back to the house to pull the drain while the garden hose filled it with the pump running.
That air is plenty hot when it gets compressed to 35, 40, 50+ psi. Charles's law
thats the first time in the laast 5 years ive missed that pull im realy mad because ive never seen you or a 900hp d max there either that sucks i loved watchin your truck go down the track at front royal
you may have seen the dmax, he had been having trans problems and it wouldn shift. hes got it right now, when that thing dont shift it doesnt look like 900 but when it does look out.
