367 but throw a better HPOP on there and you could be very close to 400. Dynos can vary significantly as can how your truck is setup such as a tune or switch to lock the converter to see a more realistic power.
Good luck and post your numbers and sheet when you get them. How do you like the combo so far for driving etc..?
I have plans in the future for an Adrenaline, but I just put in the turbo and injectors... I wanted to keep it in the "safe" zone for pmrs and also keep the egts down as I tow with it a lot of the time. I will dyno on July 10th and post what I see still using my stock 17* pump.
Never ran the truck in the quarter? That would give you your truest hp number. Dynos are tuning tools. They all differ. My guess would be higher than 400hp with the mods he has.
Can one of you guys explain or lay out exactly how track times are a accurate measure of RWHP? How the different variables going down the track are accounted for. Have always wanted tpo have someone explain it in some detail. Thanks.
You guys won't believe this, but here is the result. Dyno Runs 2009 is what I dyno'd last year with TW tunes, stock injectors and stock turbo. Dyno Runs 2010 is what I did today with PHP tunes, Swamps stage 1's and a 38r. I couldn't believe it. 251ft/lb gain on torque and 70 more horsepower.
