long answer...........you will have to put a freeze plug into the spot where the mech fuel pump is at, and unless your changing injectors you will need tunes to run the small AA injectors.
It is a freeze plug. Not sure of size. Measure it and get it at the nearest auto parts house of your choice. Try to find a real parts man, not just an employee. They will be lost.
alrite thanks you all and i was also wondering for a turbo for the 95 motor can you use all the same stuff off the 99-03 7.3l like turbo mounts or is all that different
You can, but you have to change everything over. Up pipes, collector, turbo, pedistal, intake Y, intake plenums, intercooler (added) and intercooler pipes.
That is why I went with the H2E, I had to change everything anyway, I could get the H2E kit cheaper than getting all the parts to switch from a early 99 to a 99.5 and up.
is the block and heads and crank the same on the 95 as in the 2000
