hey guys i have my motor pulled out to do the headstuds and rear main seal and was wondering what cheaper mods could i do while the motor is out and do you think i should upgrade the torque converter since its right there?? there nothing wrong with the trans i was just curious to know if it was a good thing to do and if it is which one do you guys suggest? i already have a egr delete and intake n down pipe...thanks guys i could really use the advice asap!!
If I had mine out right now.....again.......I would probably be rebuilding my oil cooler and if I had the coin to spare... torque converter for sure. Maybe work on fuel delivery... ie banjo bolts , throw in a coolant filter for good measure. Depends on how far you want to go with it.
The coolant filter will help your oil cooler live longer and at a fairly cheap price, I think they are under 200$ from dieselsite.
107.4K members
