For those that know these things...
ATS 3 with about 30k on it. It's been used for what it was built for.
A couple weeks ago when WOT, it developed a slight slip/shudder on the 2-3 shift. Shifts fine part throttle, TC locks up when it's supposed to, once locked in 3rd gear it pulls fine with no slip, every other gear is just fine, etc.
NO other issue that that shift.
ATS says they're gonna take care of me , but there have been some issues gettin the ONLY trans shop I'll let touch the truck and the gentleman at ATS on the phone together. Either ATS doesn't call back or the shop "is to busy for the phone."
So I've been takin it easy on the truck until we get something figured out.
Had no codes and no issues drivin it until today, when I left it idling in 90+ temps for about 15 minutes. Trans was 180* fluid and 191* on the scangauge when I got back in the truck.
Left the house with the wife to head to town, drivin easy. Trans shifted outa first part throttle at about 10-15 and locked the converter as soon as it hit 2nd.
Tuned to lock at about 30 WOT, and about 36 part throttle.
Let off the throttle and it unlocked, rolled back into it and it just reved the engine. Backed back out of it and it slammed into 2nd with the converter locked. Rolled back into it and it acted fine. Weird I though, but I kept drivin, hopin it was just a fluke.
Got out on the highway and it did close to the same thing, but locked (slammed) on the 2-3 shift at about 28 MPH this time.
Got up to highway speeds (55) and everything was feeling fine, then it dropped outa gear and free reved, then slammed back into OD with the converter locked. Then the converter performed a really interesting rapid fire lock/unlock routine and downshifted to 3rd and locked back up, and wouldn't shift to OD.
OD light started flashing at me at this time, so the wife and I gave up on our date and turned around to go back to the house.
Trans attempted to repeat the performance all the way until I locked out OD and kept the speed at about 40. Was quirky with OD locked out, but didn't do the "slam-bang I hate your guts show" anymore.
Got to the house and parked the truck. Let it sit for a couple hours while I pulled the codes, P0500 and P0721. So, I went over the wiring harness to the OSS and the VSS, and didn't find a single issue, so I started the truck again and went for a drive.
Trans had cooled down to about 160* fluid and scangauge at that point. It didn't heat up anymore during the drive, and didn't repeat the afternoons stunt. Drove just like it has for the past few weeks, still slipping/shuddering the 2-3 shift ever so slightly.
When I first contacted ATS and told them the trans had 30k on it and I was havin this issue, the gentleman I talked to thought it would be something in the soleniod body since I had no other issues with the trans, and asked me to have my trans shop get ahold of him.
My trans shop thinks it's something else.
I'll be in colorado for the next two weeks, without my truck, and was planning on stopping by ATS to speak with them about a solution.
Should I ask for a solenoid body to hand carry home with me? Or am I chasing my tail there?
Could it be something as simple as having the truck tuned without trac bars installed, and now that they're installed I just need a little more line pressure on the 2-3 shift?
Or does todays performance indicate electrical issues, and not simply an unwillingness of said electrical components to work properly when hot, ish?
Thanks...
Thanks...
