After cruising the Traction Bar threads for quite a while, I finally got around to building mine. Here's some teaser pics of the bars we built this weekend. 2" OD DOM with heims at one end and Ballistic bushings at the other. 84" long and painted to match the truck(True Blue). Randall (fordsuperduty05) will have full build pics to follow and I'll post some more up once they're mounted...
man lance you cheated i am here at work and your at home painting traction bars dont worry though mine wont be to far behind i should be painting mine tonight hopefully and will have mine mounted up before the end of the week
I'm in North Dallas, bout 20 min from Rowlett. There are several of us on here that get together regularly for lunch so we can look at setting something up while you're here if you like...
he did fail to mention that the juice is running on storage fee's. you're now up to $47. using compounding rates, it should be up to about $762 by this weekend if you want to come pick it up.
yes i bought all of my stuff at balistic fabricarions and i believe lance aka stroke of luck bought his bshings and mounts from there but bought the joints from barnes but i bought all of my stuff at balistic fab
yep bushings and brackets from ballistic. rod ends, misalignment spacers, lock nuts from Barnes 4wd.
107.4K members
