Had a noise comming from the front of my truck, pulled the front hub lock unit out and the grars inside it are grinding and causing my noise. I called Ford and they want $422 for it. Is there a good aftermarket replacement or even even a manual lock unit i can get? Looking for suggestions.
Is it the hub or the unit bearing assembly? If it is the hub than Warn makes an upgraded hub for them. If it is the unit bearing than none of them are cheap.
