i just picked up a 00 crew cab long box superduty and was lookin into either a leveling kit or lift kit. i can get a set of front ford highboy springs for cheap, and was wondering what kind of lift i could expect from them. this is on a v10, so its obviously not nearly as heavy.
You can use X codes and get 2"+ lift. You will need a adj track bar to recenter the axle as every 2" of lift WILL shift the axle 1/2-3/4". We have them in DOM and Billett Alumnum.
Longer shocks will also be needed..Bilsteins.
PM if we can help.
Factory Front springs used on SD that had the snow plow package. They are a bit stiffer obviously but still better than most every aftermarket spring.
