ok if you can get a resivor off or an international school bus you have it made. the school busses run a powersteering pump off of the front side oposite of hpop but this hole will accept another hpop in a nutshell.
The PS pump is run off the backside right above the HPOP, and that housing will not accept a HPOP. It will, however, accept a Haldex gear pump. It's called a Gen3, from Swamps. And good luck finding one of those housings now.
OP, you'll need alot more than just an adapter plate to put two HPOPs inline.
You can get them used, but you won't find a new one anymore. That is why Swamps went to a billet reservoir. And the only way you'll get a used one around here is if you buy the complete motor, and those prices are way out of line versus what I can get a used PSD motor for.
Dave
