Well after the the dynoing in ts put a little hurting on ****** were starting the build
Parts list
Oil cooler delete
Carrillo Rods
.020 Elite low comp/coated pistons
66/74 OVER S483billet from bullseye twin turbo setup
Bodacious Intake Manifold
Billet pushrods
Hoping to have everything done for ts in july
I will post pictures as the build starts in the next couple days
You guys just can't stop in the bodacious thing can you
boadacious has allitle more time into his and quality control his oring is oem standard thinkness
You guys just can't stop in the bodacious thing can you boadacious has allitle more time into his and quality control his oring is oem standard thinkness
If you want to discuss the intake manifold then follow Snake's link, other wise keep this clean for Craigs n Mikes build up. This has been cleaned again.
I see you in here. I really hope you are posting a big long list of what was wrong with the one I sent to Nate. Which you are using on another customer's truck.
how can i get in touch with this company bodicaous there website is blank no number or nothing
